ET 967 Tuning Thread
This is what I am running with the Zeel on a ET967, dual 46s, PFP pipe, and 180psi.
Jetting:
2.3 n&s
110 main
120 pilot
95 gram spring
Zeel:
18* at 1000rpm
33* at 1800rpm through 5400rpm
26* at 5500rpm
19* at 6000rpm
14* at 7000rpm
Never get into the high range due to all the power being down low. Hope this helps...
Jetting:
2.3 n&s
110 main
120 pilot
95 gram spring
Zeel:
18* at 1000rpm
26* at 5500rpm
19* at 6000rpm
14* at 7000rpm
Wow, quite different than what ET suggested for my ski (identical setup/components):
125 pilot
135 Main
2.3N/S
115g spring (17-18psi popoff)
I just ordered my engine so I can't comment on how it runs till Spring/Summer. I'll let you guys know how it goes in April/May :)
125 pilot
135 Main
2.3N/S
Funny, Art originally told me 125p and 120m. Gave that a try, but was definitely fat and slugish. I got the jetting spec from someone local who has built a few of these motors, and 120p and 110m was the recommendation which seems to have been spot on. This is also in Florida / Sea level, so don't know if it changes for where you might be. The piston wash in spot on.
joecef
Live fast, Die Fat
Canada, EH
125 pilot
135 Main
2.3N/S
Art told me the same set up he told uou. But I’m running 48’s
125 pilot
135 Main
2.3N/S
I do believe builders give a basic starting point, which is just that, a starting point. I have noticed with a few friends that have gotten specs for other motors from builders that where way fat, but I guess it is better to be fat than lean.
Without a doubt, you don't recommend the "perfect" jetting to a customer because it's nearly impossible. Too many variables with different quality fuel they use, elevation, water temps, pump loading, etc.
As long as it's reasonably close I can fine tune. I just don't want to get my ski on the water and it barely runs with the recommended jetting.
Sent from my SM-G960W using Tapatalk
joecef
Live fast, Die Fat
Canada, EH
Anyone running oem 155 with the 967? I would like to know what pitch people are running.
I’m running a stock 155 with a cut back 6/11 I believe. I have it all written down. But if you scroll through this thread, it’s been mentioned. I was going through a tuning process this passed summer.
Well then you may as well go to the 897x comp engine for $200 more. I personally went with the 967 because I do not want to deal with +10mm stroked cranks due to the increased frequency of rebuilds and associated rebuild cost.
Jcary85
Vendor Account
Glenmoore pa
Anyone ever asked art what he gets for a new crank? He builds his own these days. I also wonder if he does rebuilds? Gotta be cheaper then a $900 normal crank rebuild right?
