- Hokesbluff,al
down here in the humid south, gils setup works great. top open a smidge and the rest closed. guessing pipes might be a little like carbs, depends on where you live what setup actually works
Im not a factory B pipe fan at this point.
Mine are all closed :laugh2:
I am still getting used to Art's magic that he does.
I would PM you some questions about this setup, if you are willing to indulge them.
and I do appreciate your advice, even though Ive nearly wrecked this thread for simply trying to bring it to light.
I agree I would run a speedwerx freestyle pipe in a heart beat. And I will when I find one. But for now Art told me to set the top 3/4 to 1-1/4 out and the bottom just a shade less than .5 out. He told me to adjust it so that it would steam water at half throttle runs.
Double check all hoses, bolts and clamps from your installation. For the first "on-water" test of your new Factory Pipe we recommend closing the top and middle adjustment screws and opening the bottom screw 3/4 turn out from closed. This setting will be more water than is required but will provide a good starting point to test the pipe.I can say for sure..
on a 61x stock, OR with more compression.
the top screw makes the pipe suck balls.
there is alot to the pressure, line size, and routing.
but I swapped a coffman sizzler for a B pipe, and it isnt making nearly as much power.
I have to modify an allen wrench to adjust the bottom screw with the headpipe installed.
I initially ran top screw at 2.5 turns out, all other screws closed.
it ran like a 650 on ONE cylinder.
I closed the top to .5 turns and melted a hose off. [ but ALMOST as strong as the coffman pipe]
i opened the mid to 1/4 turn, with the top at 1/2 turns and its running, and NOT melting hoses.
but it still wouldnt outrun a fat chick without a paddle....
Are they really? You posted a rolling laugh???
I personally could'nt care less about you, you are rarely helpful, and even rarer yet are you actually humorous.
