- Michigan
Hi Guys,
Curious to what temperature the head pipe should be. I recently did a motor swap freestyle ported 701 to a Dasa 850 stock stroke. The B pipe mani has dual cooling.
When I was running the 701, I had the top two water screws closed and the bottom open 1/4 turn. However, with the Dasa running the same - I melted the top cooling line that runs from the top of the head pipe to the flow control valve then to the chamber. I used my temp gun after riding for a couple of minutes and the top of the head pipe was reading close to 300 degrees F. Motor was around 120.
Obviously I need to open the top screws up to allow more water to cool, but does anyone know the optimum temperature for exhaust flow?
Thanks,
Ben
Thanks,
Ben
