- Pennellville, NY
Ok Got the pole on. The braket that comes with the ski has the provison for the pole spring bracket. I like
pole springs so i don't have the feel of always picking up the pole. So after getting the brcket and spring all installed I could not get enough tentions on the pole bolt to keep the pole in place. Spring kept wanting to push the pole all the way up. So I removed the spring. Then I couldn't get the tension right without the spring. When I tightened the pole bolt both the bracket and pole would just crush. So I have to install RRP's pole anti crush bushing. Then I was able to get the tension right. I will have to revisit the spring agian and find something that works.
