Freestyle Feedback on Mag impellers in OEM pumps
Pablo
sqeez bth levrs & lean bk
georgia
Anyone running a mag prop in a OEM SJ pump please provide feedback on performance changes.
I'm running a blueprinted OEM pump w/ 9/15 Hooker and need to upsize my prop. Was thinking of repitching to 11/17 or possibly going all the way up to 14/19. Engine change from ported 760 BB to SS 850 PV setup. Impros recommended the 11/17 but a few peeps on here with similar engine/hull setups have said they needed more prop than 11/17. I'm going to try a C-75 12/17 first before the repitch effort. Really need a mag pump but the wallet needs a break.
As an aside, are you guys sealing your pump gasket to the pump shoe with any silicone. I did that on my first few builds and hate doing it now since I pull the pump more often and its a biatch to strip all that silicone every time I pull it.
Pablo
georgia
aren't the Hookers a mag impeller or very close to it?
I thought the same thing, but was wondering if there was much of a difference in hub diameter? The Impros guys call the Hooker a "big hub" impeller...that's a mag impeller to me. Does a TBM cone fit over a mag prop?
OCD Solutions
Rentz, GA
I had the understanding that a stock pump with a pump stuffer and C75 mag impeller was very close to a mag pump except cheaper, that's why X-Scream promotes it so much. The big difference remaining would be the vane displacement.
chriselmore_1
high on resin
san jose ca
I'm goin stock 144 and I'm gonna run a tbm and mag prop for my 10mill pv motor. Just got the 10mill motor and a new hull so the wallets a little to light at the moment for a mag. Have no idea where to go on prop pitch though
chriselmore_1
high on resin
san jose ca
I've heard alot of good and bad about hookers. I've bean told they are verry forgiving and great for people that don't know how or have the resources properly to tune a pump. I've heard they put too much of a load on the motor.
I know Jetworks and Xscream both prefer the C75 over the hooker for bigger motors. I was told the Hooker causes some hesitation off the bottom in the 10/16 and the 11/17 pitch.
D-Roc
I forgot!
is the hooker made by solas? I run a skat swirl c-75. that is a mag prop. I use the TBM super cone with the shortest of the three cones. I found that my solas prop would let the motor rev up and then push the ski. the skat pushes the ski right away. I would only use the c-75 or big hub in combo with the TBM.
Tuscaloosa, AL
The hooker is made by IMPROS. Yes, the Solas Concordes have a lag before they 'grab' the water.
I am running a 10/16 Hooker on an 82mm TLR Ported cylinder with stock pump. No Issues, No lag, Instant hook up.
Tuscaloosa, AL
I have not found this. I started out with a 10/16 Hooker on a Big Bore and then dropped back down to an 82mm bore. I thought that I would have too much prop with this setup but that was not the case. Works really well. I could probably drop to a 9/15 but I would lose some top end speed. Either way, this prop works well.
JetManiac
Stoked
Vendor Account
orlando
I'm running a blueprinted OEM pump w/ 9/15 Hooker and need to upsize my prop. Was thinking of repitching to 11/17 or possibly going all the way up to 14/19. Engine change from ported 760 BB to SS 850 PV setup. Solas recommended the 11/17 but a few peeps on here with similar engine/hull setups have said they needed more prop than 11/17. I'm going to try a C-75 12/17 first before the repitch effort. Really need a mag pump but the wallet needs a break.
If you are repitching your Hooker impeller, then you should work with dave at impros to find the correct pitch. He designs the impellers and should be able to help you best.
TBM cones in combination with big hub impellers will provide you with a 'poor man's MAG pump.' I used to run that setup with my XS865. They will hook up better than a stock pump, but are NO substitute for a MAG pump. The TBM setup still leaves you with a bighubbed oem pump with long thick cast aluminum vanes. The MAG pump usually has 12 vanes that are much shorter and much thinner stainless steel. Additionally, the center hub is smooth without the joints found all over the TBM.
OEM 144mm Yamaha pump vane section was designed in 1990 when Yamaha introduced their 'powerhouse' 650 motor in the superjet and WR3. It was never changed or improved when they introduced the 61x 701 motor in 1994 or the 62t/61x motor in 1996.
In 2008, yamaha redesigned the SJ hull bottom for better hookup by changing the pump intake area and by lengthening the driveshaft and moving the whole pump back by 2". This setback of the whole pump is not be confused with the setback stator vanes within the Mag pump, see below. This improved hookup but still didn't change the original pump design. While it is super impressive that the oem pump designed for an anemic 650 will still work for with a ported 701/760 with a bpipe/etc. It also isn't an optimal setup for performance.
MAG pumps have bigger hubs to increase the pressure and the power of the thrust out of and through the pump. They also have more veins which are redesigned and thinner (stainless vs cast aluminum) so they straighten the water flow better. They also will produce thrust even with less than optimal water flow, which is most of the time when you are riding. Another big difference that I notice is how quickly the MAG pump will rehookup when you land. When you ride in choppy water, it is amazing the difference.
The setback MAG pump requires a custom setback driveshaft. The pump stator veins are moved back (setback) closer to the reduction nozzle. This leaves room for more water in front of the pump for longer hookup. I have never compared the differences directly to be able to comment on the difference from actual testing.
As far as sealing the pump to the shoe, I prefer to align the pump/wear ring and seal it up well. Whenever you remove the pump after that, leave the wear ring sealed and aligned in place, just remove the pump/driveshaft for impeller swaps.
GIL
Power In The Hands Of Few
Cullman AL
This is MY experience so take it for what it's worth!
838cc Lamey, t/l, blackjacks, MS109, 85mm exit nozzle, blah blah blah. The C75 12/17 with a TBM is too much and slows my revs BIG time. I ditched the C75 and the TBM and went to a Hooker 10/16 and love it. Also have access to a Hooker 9/15 and love it as well-can't FEEL much differerence between the 9/15 and 10/16.
need more powa!
D-Roc
I forgot!
771cc PV Dasa, TL, Powerbombs, sunoco 94 85.5mm nozzle i ditched the solas cutback for the tbm/c75 because of too fast of revs and not enough ommmphf. That was not a hooker prop though. i like my motor to work. how many riders does it take to figure out a prop? haha. If you want the best, buy the best which is a mag pump. no one can argue that, finding the right combo for your motor, ski/rider weight, and water conditions is up to the rider.
McDog
Other Administrator
Staff member
South Florida
You can get a new 144 for around $1100 with your choice of prop from Jetmaniac or Taylor Curtis.
