speedysprocket
Alex
- Chesapeake, VA
Was wondering if maybe you had two single carbs so the master wasn't giving the slave proper flow or pressure. Sounds like that shouldn't your issue though.
It's easy to check reeds? lol. Took me 40 minutes just to take the carbs off when they were in the ski. There's zero space in there! I'll take a look though.
B.E> if you got spark and compression ,and the ski runs. i'm going to say its your jetting combo .you added a ton of timing from stock down low ,but didn't add any fuel ,its probably falling on its face lean. let me guess ,its hard starting and it wont idle either ?
Yes it should be a cunt hair close to almost flickering as soon as the led turns on it will fire
Sent from my SAMSUNG-SGH-I337 using Tapatalk
