The carbs are in sync together, that was my first thought too. They are in sync, I'm not sure how to verify that both carbs are getting fuel. When I took them apart, they both leaked all their fuel out heavily. I blew all the passage ways out with WD40 and there was no blockage. My pop-off pressure is about 55psi on both carbs. Should I be able to verify I'm getting fuel in the front cylinder if the spark plug is wet? (there is no color on it yet, but I could check if there is fuel on it right?)
In all honesty, it feels like it is only running on one hole, up till some X RPM where all of a sudden it will hit and run normally. It's odd, man..
It runs great when out of the water, I think because it is able to get up to that X RPM spot where all of a sudden it kicks in good.
