Sweeeeeeeet!!!
Update:
Here is what I did for my ride plate...
I think it helps. I am thinking about how I am going to narrow it up a little more. We will see...
I just finished swapping my cooling and ignition by changing to reverse cooling and Zeeltronics. Also changed the waterbox to a JM Waterbox (which is sweet btw), new Bpipe coupler, long hose, and a coupler that connects a piece of pipe to the pipe that goes through the hull. Through the course of things I found that the 760 electronics I bought had a bad do-hickey (Voltage regulator maybe). I swapped it from my old ebox and ended up changing a few original plans around. Here is what went bad...
Everything ready to close up
Ready for the water
Here is the #Zero flywheel installed... super light and looks good too.
I am excited to drop it in the water and run it.
Ill let you know how it goes.
