Quinc
Buy a Superjet
- California
Would it be worth hitting with a power washer before I start sanding?
Careful with a pressure washer. An electric pressure washer or a very wide fan from a gas washer is great for taking the foam out completely. Gas washer with a narrow stream can cut a boat.
Grab an air powered da sander?
Air tools are good for taking things down fast but not doing a quality job.
Jeeeeesh..imagine flopping a roll with that layup.. Woulda smashed the whole side. Thankfully you've been just cruising around and working on flips!!Picked up the smallest 90 degree die grinder I could get and some flap disk wheels! Making things go much quicker!
Had some more fun today. So anyone have any guesses why there is foam blocks all over the inside of the ski? Filler? Or maybe used for shape? The engine bay and the sides of the ski go like this:
Resin | Foam | 1 sheet of very poorly laid carbon...
It is normal to be able to rip out the carbon right?
[/img]
Foam behind the carbon.
Can I reuse this?
Yeah I think it is gel coat.So what's on the other side of the fiber. That just gelcoat?
Outside of ski (gelcoat) | Resin | Foam | 1 sheet of very poorly laid carbon
