Injected the bondline where it meets the firewall with a syringe this morning and then put two layers of 12oz over it.
Move the ski this evening to put some more glass on it and noticed a decent amount of resin on the ground under neath it...
Pro Tip: If squirting resin inside the bond line, tape up the outside of the bond line first... Going to Inject the bond line from the outside next.
Inside of the tray:
Firewall - Filled in all of the gaps with WC 404 filler/epoxy mix followed by 2 layers of 12oz along the
Cracks and leaks - 4 layers of 12oz and 1 layer of 4oz s-glass. Last layer of 12oz covers the entire side of the ski.
Rest of the tray is a mix of 1-3 layers of 4oz and/or 6oz depending on if I think the area might be prone to leaking.
Would there be any value in painting on a thin final coat of epoxy after the glass is dry to make sure no water is going to leak/weep in?
Bit a panic when you see this under your ski and know that you haven't spilled any.
