fixing a gas tank
Mouthfulloflake
ISJWTA member #2
NW Arkansas
could you drill the hole slightly larger, and screw in a brass fitting with a hose barb?
LIke this?
anything that will adhere to the tank? I need to repair one of the little nipples on my fx tank...:Banane35:
Mouthfulloflake
ISJWTA member #2
NW Arkansas
5200, or PL adhesive it into place maybe?
PL sticks to ANYTHING.
OR, several wraps of teflon tape?
thats what I did...but I made the hole ever so slightly too large....if you wiggle it you can hear the air hiss...
I either need to drill it out for a bigger one, or epoxy the one into place....
Mouthfulloflake
ISJWTA member #2
NW Arkansas
or, seriously.
duct tape over that hole ( it will hold for a WHILE) especially if you put a couple of layers, so the splashing gas deosnt get to the outer edges.
then just drill a new hole for a smaller barbed fitting?
DAG
Charlotte, NC
when i taped my kart take for a nipple i have somehtign simmeler and i used 5200.. working so far... :fingerscrossed:
sjetrider
5200 seems to be fuel resistant not sure about the others. 5200 fast cure would be my recomendation, but I also though maybe Threebond as it is also fuel resistant. So if one is more readily avail I would go with that one.
skinnyman
YOU CANT RENT MY SKI
Dallas/ToyBox
I went to a mx shop and got a valve stem
drilled a hole the tank
Put wire from pick up opening out thru hole
run wire thru opening of valve stem
make a bend in wire
pull valve stem thru hole
tighten nut down over Oring
your done
Not sure if Im clear on this but when you see a valve stem it makes sense
Big Kahuna
Administrator
Tuscaloosa, AL
uh, but I got a 6 month old who is a master at it!!!!!!!!!!! you should hear Anita scream!!!!!!!!!!!!!!!!!!
Yeeeeoooooccchhhhhhhhhhhhhhhhhh !!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
