- Minneapolis, MN
I take it the pump stuffer is no good for low end / freestyle?
Looks like you left two giant rudders in the rear of your ski. I was not talking about moving the rideplate mount. I'm talking about not being able to truely shorten your hull by much being as you left the pump tunnel basically at stock length. If you really wanted to do it the easy way why didnt you just do a deep D cut on your ride plate.....? By not cutting it past that last rideplate bolt it does not look like it will ride any shorter than a stock length ski with a D cut plate.....And you cant modify the plate however you want because you are now limited by the rest of the hull you left hanging out the back.....thats what I was getting at.....
I just shortened my SJ by 4 inches..... Your ride plate is still gonna be out by the steer nozzle with all that pump tunnel you left. All i'm sayin is you should have chopped the rest off then you could truely mess with the length by just adjusting your plate length.
:beerchug:
Really...?? Bcuz you get alotta surf time in Minneapolis, MN right....??? I have heard the ocean is awsum up there! :laugh2: Just trying to help.....
I had one of those a while back and just cut the stuffer off of the grate, worked just fine.
dude your hull is gonig to be ready to ride before mine even comes, dick!
I'm keeping the pump cone until it gets here.
