Idok
F1pro
- Nations oldest muthaF+++kin city
so I removed all the foam from my tray and put it in the tank......now where do I put the fuel?
I read the previous pages and think i did everything backwards. I put foam in the pole, which is normal, but somebody told me putting aluminum foil in the gas tank would help with my bottom endThe obvious place would be in the handlepole would it not?
ok, ok, I'll let you in on the real secret:
put the foam in the tank, you know that already...but then WRAP the tank in FOIL.
This filters out the high frequency noise generated by the engine, which can break down the brap molecules...and it adds BLING, BABY!!!
It's a win - win...
aluminum foil only works if you used hydrocloric or sulfuric acid in your fuel tank.
