ok.... I'm back on this thread now...
I did the glassing last night.... It took 2 solid hrs of laying glass... I really took my time and did it up very strong and thick!!!!
a few things to notice...
- the tray was pushed in on the sides in front of the footholds a bit to make it wider.. maybe an inch or so..
- the holds are completely reshaped on the rear where your feet slide in.
- I opened up behind the foothold to give me more tray area
- I removed the top part of the foothold, so my leg won't rub (like 24-7's do)
- layed two layers of biaxial weave on the tray
- and one -two layers around the holds..
- this glass we got was every bit of 3/16" thick... amazing stuff!!!!
- foamed w/ 2 part Hi Bond 2lb foam
- no rear exhaust, single front only for less chance of leaking into tray
- 5200 all thru hull fittings (both sides)
that's about it, I think..
first pic: I got 16" of room behind my holds now and 21" total from foothold to foothold on the inside furthest point. that is a huge increase.
Not to mention the hold goes forward for maore than half the tray.
second pic: different angle
