onesojourner
I use a thumb throttle.
- springfield, mo
those balls that mark pointed out are chemical resistant.
what about the HEAT generated by the foam? I'd test them as well to see at what point they start to melt....
How much does 2 lb foam add in weight before/after foaming? Anyone know?
come one man.............. 2 lbs.........
that really is a good question, I have 4 lbs that I am using.
Uh, not sure thats sarcastic or not. I mean for 2 lb density foam. I understand that 2 lbs of foam weighs... 2 lbs.
:biggrin:yes. ^ . Air is my buddy. Here's my newest thoughts. Why do we need ping pong balls in their anyways? If the compartment is airtight (or close enough) it will still be very bouyant. Much like trying to push a closed pop bottle under water.
The only issue i see with that is if you have a failure, and your hull cracks, or gets damaged. Water is coming in and your air is going out! Ok. Balls are good.
Second note- I just got done with the ole calculator figuring out the Volume of the cavity. It is approx. =
4387.5 inches cubed.
or
2.54 ft^3 of foam in the rear (excluding exhaust and scupper tubes). So for 4 lb foam thats 10 lbs of foam, and two pound foam thats 5 lbs...dry weight
worth the work?
That sounds like that would work a lot better then ping pong balls, crushes still easier then regular foam, but is a LOT lighter per the same given area. I have a couple sheets in the basement, I may even try that myself.
Why not just put the sheets in? Probably would compress a lot better that way. Individual cells sounds like it would be hard to get an even mix while the foam is expanding.
hey Nick, I would stand the ski up on the nose, put your ping pong balls or crushed up foam in about 6", then pour foam so it runs into the voids, the pack and pour.... repeat until full....... instead of trying one big pour.
I'm open for disscussion bro... lets work it out
larger pieces are good for the gunwhale area... I was just thinking smalller chunks = more polystyrene per cubic inch of foam...
