Rickster
Matakana Menace
- Bay of Plenty, NZ
The weight of the foam is probably less than the amount of glass/resin you would need to make the boat strong enough to not use foam.
I just re-foamed my square after completely re-building and re-inforcing the back, and the 4# closed cell marine foam added about 13 pounds to the ski.
This foam is USCG approved for fuel tanks and flotation, and based on the container half filed with foam then a measured amount of water on top that has been sitting over night, it does not absorb much water if any...
13 pounds is not a lot of weight in my book, considering it is closed cell foam, and the ski will be used in surf only.
:cool2:
