Want to Buy Found
I have conversion brackets, and may have a pole. (Well, I know I do, I just need to look into a repair for it maybe?) It is RN pole that someone hacked up the bottom mount to fit a stock SN bracket. I am NOT sure if this is a good idea to run like this? Will it break? $100 as is, if you want to run like this or find a new base. I do not have any extra bases here...
Give me an email watcon@watcon.com or call my shop if interested.
Thanks for the option John but I don’t have a source for a unmodified base and was wanting to get a conversion bracket and do it right.
I have a brand new take off from a 2018 Superjet that was never used if you are interested - it is has the chin pad, bushings, turn plate, bars, grips and stock throttle. I also have a brand new steering cable if you need it. Just let me know. Thanks
RMBC Freeride
Vintage
Pueblo, CO
Found it
Sent from my SM-G950U using Tapatalk
Does anyone have a chin pad that they want to get rid of. Looking for one to go on a 2016 stock superjet. I am not really looking for a expensive one just one I can take and put a cover on.
. Is this still available? Would you separate the chin pad from it?
