- HOLLAND MA.
Figured id make a thread on expected runtime on these
convigurations. These will be put in a all out class, for example fully ported, epox cases with billit plate or full billit cases, dual 48 or 49 carbs, 195psi and up/flattops, we will throw msd tl in as well.
8mil
10mil
12mil
16mil
I was told by a couple builders that a 8mil setup with 85 bore witch i have has a runtime of aprox 32hrs before a top end break down for inspection possible freshup with rings and pistons and 62hrs for a lower end rebuild or inspection.
With the 10mm i was told full comp motor witch will see a breakdown every 25-30 gal of fuel.
Now is there any truth to this, i know diff builders and setups will prolong the life but lets say it was build right and followed the specs shown above. I picked my setup not with price but on runtime and if it could meet my needs. Backflips, and still be able to perform basic tricks with control...such as hood trics ect. Id like people to chime in that have had these motors and a word from engine builders on this subject. Pro's and cons on big stroke with 85 bore vs the xxl big bore 91mm. Is it better to build a 8/10/12 with a 85 flattop or go all out to 91 bore
with the same strokes. We will asume cost does not matter
on this subject. I see run time getting lower as the stroke increases for sure due to rod angle...but are the hrs or gals in the right ball park for teardowns?
8mil
10mil
12mil
16mil
