freestylegeek
waiting...
- Grand Rapids, MI
Well, here it starts.
I sold my beloved 1996 hull (with my sacred 24-7 hood and nosepiece).
Now, I'm building a squarenose conversion.
The new hull started out as a 1994 squarenose.
I cut the top deck off, and removed the foam.
I removed all the stock sealant around the waterlines and driveshaft tube.
I moved the steering location up and to the right in order to clear the cooling line boss on the pump, and make my trim more effective.
I cut 2" off the back of the hull in order to help with flatwater backflips.
My top deck and hood kit ship out from XFT on 9-29-06.
The top deck weighs around 13 lbs and the hood also weighs 13 lbs.
The squarenose hull bottom weighs 56lbs.
My goal is to get as close to 80lbs as possible when the hull is complete.
I will post a few pictures of the start of this project.
I will be updating as I go along.
So far, it has been way more fun than I thought it would be.
