OMG you’re really modifying this hull!
Do you think your steering nozzle will hit the sides of the hull after its two inches shorter.
Just curious where do they glue the hull halves together, is it glued between the top and bottom, around the rails or both? What type of glue are they using and how hard is it to separate them?
The steering nozzle will have even more clearance with the hull being shorter.
The halves are glued primaraly on the top of the bond flange.
Some of the adhesive may work it's way down the vertical edge of the flange, but it's designed to be bonded on the top.
I will be using Either MarineTex or ITW Plexus for bonding adhesive.
On a side note, one of the nice things about buying a complete hull from XFT is the fact that he has equipment to bond the top and bottom with epoxy resin. Basically, it creates a 'monocoque' type design where the material is all one thing from top to bottom - no bond line.
It makes the structure lighter and stronger.
