ArtMaybee
I'm Baaaack!
- Mobile, AL
Has anyone tried getting heavy mil contractor garbage bags, you can shape (cut) the bag, weld the pieces back together with heat or glue and then fill the plastic with foam? The plastic should keep water from getting in your foam to begin with. 8m not terribly fond of using cut styrene foam since the expanding foam acts as a core to add strength to the rear of the ski.
