E350
- Sacramento Delta
Hey all you FX-1 guys and gals:
I am seriously considering buying the Blowsion Destroyer Sponsons - 2008+ Superjet/FX-1 - White
1. @FX1Dave / @wavewarrior has mad skills and can do anything with his FX-1 and he has no sponsons. So, I know that sponsons are not necessary for those with mad skills. I am getting better, so should I just pass on front sponsons and tough it out?
2. Or does the FX-1 benefit from front sponsons?
3. If so, how so, i.e., what will the effect be?
4. What is the best position on the FX-1 ?
5. Are the Destroyer sponsons "adjustable?"
@kevbo says sponsons "'pull down' whenever they touch fast moving water." What does that mean?
@wydopen likes sponsons as low as possible? Why? And not up under the bond line. To allow the bond line to still grab water to carve? (Like green face of wave?) @wydopen also has an FX-1 what do you like and don't like about front sponsons on the FX-1?
@fastgtfairlane and @Freakie say that the low position creates chine walk on flat water at speed. That does not sound good.
Related +08 SJ thread:
Thanks for all your help.
Sponson position for surf???
Hey guys, I got a 2010 superjet I’m putting pro watercraft front sponsons on. My question is for a surf free ride setup where is the best position I figure there are three possibilities. 1- flush with the bottom of the hull 2- flush with the inside of the rails 3- something in between the above...
www.x-h2o.com
