- South Florida
I ordered the polyester primer today. $50 freaking bucks for a 1 inch by 3 inch spot. If anybody wants some, I'm gonna have plenty left over.
does anyone know if i can mix some dye in with white gel coat without messing up the curing properties of the gelcoat? secondly, will gelcoat cure over high temp, enamel paint with some scuff sanding?
With internal fill, I wish I was good enough not to spill any gas. I brushed the gelcoat on and it smoothed out pretty good. I brushed the primer on first though. I'll post pics later.
who makes a good urethane paint for the bottom of a smc hull?
I would probably just spray clear over the paint or leave as is. Gelcoat goes on quite rough and requires a special gun to spray.
Katie’s engine compartment it painted white with a rattle can and holds up just fine but then we don’t spill fuel in there for any reason.
