General-X Build, 1100 Kawi in a X2
Got to spend some time today on the motor plate. The idea is that I start with a JSH Alum motor plate and add the extra parts too it. This way I can build it again and be able to build it for other people. The sides I just tacked on for now till I am 100% sure its right. The rear part was fully welded but I had to grind the top flat.
As it looks right now I will need to take a inch or 2 out of the stock shaft, but I still need to spend some time fitting everything in the hull before I cut the drive shaft.
This thing looks like somthing out of Star Trek!!
Also I want to give a big thumbs up to John at Jet Ski Haven!!! He is the man and anyone looking for parts, he has them or knows where to find them. <?xml:namespace prefix = o ns = "urn:schemas-microsoft-com:eek:ffice:eek:ffice" /><o:p></o:p>
Well its a good thing I tacked everything because i need to change everything now. I put the 1100 in with the stock lenght shaft and its just too far forward. Looks like i am going to need to get the shaft cut and rework the plate.
Update
Ok Motor is in and coupler are lined up. I also picked up an Accusteer and I am going to run it over the Umi, it just has more of a bling to it.<!-- google_ad_section_end -->
Here is a full Mock up with tank. I am going to work on welding and running the Exhaust this week.
Now this is all just Mock Up. I am going to pull it all back apart and paint it.<!-- google_ad_section_end -->
Holy balls dude that is going to be crazy. Can't wait to see it go. I'm going to have to come to CT for this one. Wow. Awesome work.
For the first ride I am going to run a stock sxr pump then play around with props on the water to see what works best. That's the reason I want to run the sxr style pump
