Other Ghetto fixes/work on jet skis...
tor*p*do
Squarenose FTW
NW NC
View attachment 158108View attachment 158107
You should be in the repair biz for a while, I see it all, the best one was the Kawasaki 750 SS I bought for $100.00 apparently the stator or CDI puked in it, so someone mounted a 4 banger car distributor where the oil pump was at and ran it total loss battery coil, the distrubutor had two cylinders directly across from each other firing the motor and the other two cylinders had a wire running from one terminal to the other on the cap, there is a pic of it somewhere around here, I will see if I can find it.
did the vacuum advance tee into the pulse line?
wonder if it actually ran like that!
