- Carmichael Ca.
You can put poly gelcoat over epoxy resin as long as your resin was mixed accurately. If you used too much hardener there will be unused amines in the cured layup that will react with the gelcoat causing it to turn a pink blush color. I have used ploy gelcoat over epoxy resin multiple times on Jetskis, with no problems at all. It will bond just fine if your surface is ruffed up enough, and your resin was mixed right.
