- Redding CA
So I have these brackets I wanted to use for hose and wire anchors on the inside of my hull.. I was thinking I would drill more holes in the flange nuts for grip. Knock holes in a layer of CF and biax with a metal punch for a nice clean hole and glass them to the side of the hull carbon first then a layer of biax. I was also going to dowel at least 2 of the holes with some carbon rod in case they tried to spin don't know if that part is overkill?
Then I was just going to run bolts through the bracket with a rubber grommet between the bracket & glassed in flange nut for a wider base to sit on.
I was also going to do This for a metal plate to hold my water injection solinoids.
Any advice on if this will work fine or changes to my method would be greatly appreciated this was the most expensive jetski related purchase I ever made so I don't want to botch this hull up.
