- Costa Mesa CA
Anyone know what that they would be generally worth right now in 2023?
Problem is, i need the electronics and a motor for a tigercraft v3 build. 500 bucks is a good start, i think if the going rate is up to 1200 hundred im gonna do it. For 500 bucks ill cut that kayak in half and throw it in the trash can. Steal the sponsons and throw it on my 1994 wave raiderI’d say $500 is cheap for the motor and electrics, provided it’s not all crap. Seems like $1200-$1500 was what I’ve observed lately (full motor, carbs, ebox). The bigger problem is having to dispose of the rest of the raider. Plus the time to tear it apart. If you like to wrench, have time>>money, or simply wanna do it for the experience, $500 is cheaper than I’ve seen. If you just want a motor, buy something already set to go or at least known good pieces; IMO.
My man. Cheers.take engine, take electrics, take pump , take SS Switch, take stainless strap /hull mounts, take mid shaft, ( take Y connector waterlines , take water box, take water box U to exhaust outlet, all great parts for blaster conversions, ) take throttle cable .... cut the hull up and ditch it or throw a cheap 650 in it and sell it
cheers
Okay so either electronics work for either engine. Got it.I would say it basically doesn't matter
No you just unbolt the midshaft housing from that spacer.As i was pulling the shoe out of the bottom of the ski it ended up breaking unfortunately. Sad day. Am i going to need it for the v3?
