Super Jet HELP--installing new pistons.....sloppy on rod
im wondering how much piston movement from the front of the block to the back of the block movement when installed is normal? there was only 2 washers per rod to put in with the bearing, but there is still 1/4'' of play id say....
Blue
Judging your cheapness
St Cloud Florida
If its not to tight they wont hurt anything as long as there is still some play. I know several people that put them in and found out to late that there not needed before the motor was installed.
usa
the wrist pin bearing length dictates if you use the shims or not
use wiseco b1023 pin bearings for without shims
