- Rochester, NY
and another:
- if adjusting the throttle cable to remove slack from the lever, make sure you test it afterwards...turning the handlebars one way or the other can tighten the cable and open the carb butterfly if you've taken out too much slack.
(My friend swore up and down that his ski kept changing idle speeds and he could never keep it adjusted. This was the cause
