Other help with msd tl curves
burton391
in your house
WA
Ya he did an awsome job and was fast too. Picked it up next to my 61x flywheel and jeez this thing is light.
burton391
in your house
WA
so i got a bit of help from someone thats running close to the same motor i am.
he gave me 28 degrees advance and start retard at 5500 rpm. Max rpm is 8500 and the retard is 29 degrees at that limit.
Switch 3
S1-on S2-on S3-off (Retard begin speed @ 5500)
S4-on (Timing set up led operate)
S5-on S6-off S7-off S8-on (Max speed rev limit @ 8500)
Switch 2 W
S1-off S2-off S3-off S4-off (Factory settings as i wont be using it)
What were you using for max speed retard? S5-? S6-? S7-? S8-?
Switch 1
S1-off? (Max /min rev limit +4000?)
S2-off? (Retard +15?)
S3-on (electric start)
S4-on (start retard on)
S5-off(Retard begin rpm)
S6-?S7-?S8-?
I still need some help with switch 2 and switch 1.
Any advice
munki63
Epoxy is my duct tape
Canada
Switch 3
1-off
2-on
3-off
4-off
5-off
6-on
7-on
8-off
Switch 2
1-off
2-off
3-off
4-off
5-off
6-on
7-on
8-off
Switch 1
1-off
2-off
3-on
4-on
5-off
6-on
7-off
8-off
Thats right from the Manual http://www.msdpowersports.com/workar...t.aspx?id=1098
(Begin Retard = 5000 rpm)
(Timing Setup = LED Off)
(Rev Limit = 7750 rpm)
(Holeshot Rev Limit = 3000 rpm)
(Max Speed Retard = 6°)
(Max/Min Rev Limit +4000 rpm)
(HSR Curve) High Speed Retard
(Electric Start On)[/FONT]
(Start Retard On)
(Max Timing = -6°)
burton391
in your house
WA
that manual is a little diffrent then the one i got. not that it matters. good place to start i guess.
Pablo
sqeez bth levrs & lean bk
georgia
Here's my last Dasa 4mil 895cc curve.
28* advance (static set at 30* and pulled 2* with brain)
6000 start retard
Retard rate 5*/1000 rpm
Max rpm 9000 (13*advance at max)
