aqua said:Matt....how far do you think you raised your transfer port roofs....was it hard to keep the same angle that was presently there and how close to going through to the water side were you. i know you used a 90 degree attachment to get to them but did you also use a flex shaft. that is the only part i have left to do.....i cleaned them up a bit but being that i was restricted by the dremel tool i couldnt do much to the roofs of the ports. also...how would a handwarmer sieze a cylinder?? thanks for your posts on this subject here and on pwctoday....you were my inspiration man!!! :biggthumpup:
I didn't raise my roofs...simply matched them. I am not sure how close I came to the waterjacket - I didn't go nuts, and so far it's holding together.
As far as the handwarmer....I got in a hurry and didn't go look for a tee like I should have. So, my cooling outlet for the engine became very restricted, because the only outlet was my handlebars (not much flow at all)
That's just like running no cooling at all.:bigeyes:
