Super Jet hood liner
jeremy chambon
Need more power
rockford MI
what is the best way to get the line out of the inside of a sn superjet hood is there something that will eat away the glue or do i just cut and brake its way out?
BruceSki
Formerly Motoman25
Long Island
cut most of it out with a cutoff wheel on a grinder then get the hard parts out(green glue areas) with a chisel and a hammer.
BruceSki
Formerly Motoman25
Long Island
here is a couple shots of the hood liner we built on my buddy's squarenose. It was a couple layers of thin stuff. 8oz weave maybe. I put a few strips of biax in there afterwards to toughen in up cause it felt a bit flexy to me after it cured. He doesn't beat on his stuff that hard so I can't give it a bulletproof rating but its very light(10-12 pounds). Lighter than my WDK diablo hood or my Tom21 hood and it was custom made.
Speaking of custom made, I will never try and build a hood again. we put so many hours into that hood just to make it what it is(nothing special) and I could go buy a hood for 4-500 bucks. The day we finished building that hood I vowed to never try it again. 4-500 bucks is cheap for a hood when someone else builds it and makes it look nice.
anyways here are some pics. Hood liner and finished project pics. Its still a 90 square, just looks different. Handles the same.
BruceSki
Formerly Motoman25
Long Island
The thing I wouldve done different is never got into building that hood. I wouldve bought one instead. We probably put 40-45 hours into that hood. And it doesn't look like anything special.
I used cardboard and duct tape to make the mold for the hood liner. then i pulled it, and glassed the hood liner back in with some strips of carbon.
jeremy chambon
Need more power
rockford MI
well i already have mine all cut up so cant go back now but i was reading on carbon and glass and there are diff thickness what would u be the best stuff for the hood and some hull mods and how many layer i have a big roll of glass but i dont know the grade of it i was thinking of doing three layers on the hood its kinda thick stuff
jeremy chambon
Need more power
rockford MI
okay what did u use for the nose and did u cut out the gass that was there stock ive seen some people do that and othere that didnt i would like to do it to mine but im afaird i wont be able to get it as strong again
BruceSki
Formerly Motoman25
Long Island
I just foamed the nose and glassed over the foam. I would leave all the stock stuff there unless you are confident in your glassing skills. It will leavfe the structure of the ski there.
jeremy chambon
Need more power
rockford MI
k i will do that most likely im takeing 3" of the back of the hull but it will be a while till gi get that fare im starting with the hood then nose then foaming the hull and shorting
