High Speed Industries
Your one stop shop for quality parts @highspeedind
- Lake Havasu City, AZ
You could also heat the bearings on an electric hotplate.
Of you could use the oven in your kitchen.
Do you run sealed bearings with no grease other than what's in the bearing.
I don't think the head should ruin your grease. It's not that hot, my temperature gun was set for Fahrenheit not Celsius.
Yep righto cheers. I'll check my grease cartridge to see if it has a temp range on it. 200 F is about 94 C.
Please do! I'm killing myself trying to remove bearings out of my blaster UMI steering ( alum housing w stainless steel bearings)If needed I can also post something about removing the old bearings, all you need for that is a vice and a brass or dead blow hammer. (if you don't have either a regular block of wood and a hammer will work). I can write it up later, I just need to get some pictures first.
