Mouthfulloflake
ISJWTA member #2
- NW Arkansas
I have to admit I have wondered the same thing.
I'm convinced that the Jet-Works battery is nothing more then just overpriced UPS-Alarm battery.
You can get a 12V 18Ah AGM battery for less then half the price here http://cgi.ebay.com/ws/eBayISAPI.dll?ViewItem&item=130215200646&ssPageName=MERC_VI_RCRX_Pr4_PcY_BIN_Stores_IT&refitem=130214933483&itemcount=4&refwidgetloc=active_view_item&usedrule1=CrossSell_LogicX&refwidgettype=cross_promot_widget&_trksid=p284.m184&_trkparms=algo%3DCRX%26its%3DS%252BI%252BSS%26itu%3DISS%252BUCI%252BSI%26otn%3D4 and they will probably last just as long.
its not just the ebay ad, there are a zillion applications of the identical looking battery.
look up 12v 18ah SLA using google.
I wish jetworks would post the specs of their battery to compare to the others.
It is seriously doubtful that they actually make their own batteries.
My Jetworks has been sitting on a shelf for 3 months since the Daytona ride and I put it on the charger the other day and it was fully charged in about 10 minutes which means it was 99% after 3 months .Not too shabby .
As far as the Ebay ad goes just because it looks similar does not mean it's the same quality .
Sea Doos look like jet ski's but we all know they suck azz and balls .
I will never buy another battery even with shipping a Jetworks 3000+ miles .
okey:
You are correct. Jetworks imports their batteries from Japan. They've had them made in Japan since way back in the mid nineties. When you have batteries made to order you're given case and terminal choices. Certain cases are compatable with certain terminals. The cheap batteries linked in the post above may LOOK just like the KB-35, but the inside is what counts. The thing that kills most of our batteries is shock/vibration. Vehicles with suspension are able to absorb some of the impact that our boats see. The reason the Jetworks battery is so tough is the epoxy lock plate system. I can't imagine the makers of backup batteries spending the money on that for a battery that sits in a building it's entire life. Why would they? Jetworks actually sells quite a few batteries to Baja racers because they hold up to punishment so well. The KB-35 also has more plates than normal batteries in the same size case. Charge it with a Battery Tender and it'll last a LONG time. It's also not an 18ah battery like those linked. It's 22.5ah. I don't personally care what anyone runs, but I figured I'd clear up some of the misinformation on this. I have two in boats and one on the shelf. Since I run all total loss ignitions I always bring an extra, but have never needed it. My gang brought 4 total loss boats to Daytona and rode Fri, Sat, and Sun with no charges and no problems. Remember.......penny wise, pound foolish.![]()
I'm just curious where did you find the 22.5Ah rating of the Jet-Works battery? :scratchchin:
The Odyssey PC625 is only rated 18Ah at a 20-hour rate and 17Ah at a 10-hour rate.
The plate width is just too thin on the Jet-Works battery to have such a high rating IMO.
