That is a lot but like forever said there may be water in your box. 30lbs I don't think so maybe 3-5. Do you have a fire extinguisher under the hood? As for the rear styrofoam mine was slightly damp but the water it held was negligible.<o></o>
Mine wasn't stock to begin with had pipe, flame arrestor and ttl flywheel.
What are your plans? De-gluing the back as well?
Good luck with the diet.<o></o>
That weight was with about 1/3 full gas tank, fire extinguisher, battery, and water in the waterbox. Currently have a wetpipe, head, and lightened stock flywheel. Oh, the tool kit was also installed (that thing has saved me many times and will always ride with it in the hull) and all side bumpers were removed with 3m automotive trim in it's place. I do not think I am going to open up the back end. That will be way to much work for the weight loss. Here is what I am planning
1. Cut bottom out of battery tray. Swiss cheese the sides
2. Swiss cheese the exhaust holder
3. light weight battery
4. Aftermarket waterbox
5. Tom21 lightweight hood
5. Remove glue
6. Mount CDI to the firewall
7. Possibly run aluminum engine cradle
8. Add X2 trim setup
9. Remove back bond line and cut tray for trim nozzle
10. Remove all blowsion bling and put stock plastic caps back on.
That is all off the top of my head right now. I will be happy if I come up around 30lbs weight loss on this. I am a small guy and only weigh 140lbs. I will should feel the difference with 30lbs lost.
