swapmeet
Brotastic
- Arlington TX
Just depends. Here in TX, I've never seen anyone get a ticket for an extinguisher unless they were doing something else that earned them tickets.
This may be a dumb question and may have been answered already but Im gna ask anyways. When running a AM hull without the extinguisher do you run the risk of tickets or harassment from LEO
Not sure I followAll you have
Well dang sorry it does have footholds. Really dont even know what just the hull would be worthFlatwater, go aftermarket hull. I might be interested in buying your 08 hull if it doesn't have footholds
Ride went great today. I did alot less tipping over in tight turns and was finally able to get some nice nose stabs in. My lower back isnt to happy though. Thats probably more of a old age thing though
Oh yeah def have a spring in there. It's a blowsion spring. I'm just not used to the lowered pole yet I think. I keep dropping my elbows. When I ride elbows up my back feels much betterYou have a pole spring in there right?
Yeah I actually do have one. Ive been thinking of a spot to put it. It looks like Ill have to bond it to the extinguisher pad. I guess I could use contact cementDo you have a pole pad? Few ride and have the pole touch the hood. Putting a pole pad at the lowest position you ever use can help keep you standjng taller on landings and take some of the weight off when setting up.
Elboes up uses more chest which is good. I learned the lesson the hard way on my quad. I cased a jump elbows down and broke my wrist.
Yeah thats where Im kinda stuck. The previous owner installed a double hood strap. So I dont have a strap running down the middle of my hood. I have one running down each sideIf you have a stock hood, then that is an issue. I strapped my down using a bungee and webbing to try it out.
One of the users here glued a piece of turf to the bottom of this pad and left a gap for the ratchet strap that holds his hood on to also hold his pad on. It looked like a good idea. I think I'm going to go that route since I also have the stock hood and a ratchet kit I haven't installed. Sorry I don't know where he posted that picture.
YESSS! Sewing a loop in between the two is a great idea. Especially since I have industrial sewing machines at workMaybe you can sew a strap between them? Or sew a loop a tad smaller and when you tighten them down the loop will pull taught?
I have thought about glue but the stock hood extinguisher surface is not inviting for that job.
YESSS! Sewing a loop in between the two is a great idea. Especially since I have industrial sewing machines at work![]()
Will do sir. Thanks again for the great ideaPost pics. Id like to see what you come up with.
