LS86
LKN
- Sherrills Ford, NC
Got any pics for a squarenose pole?
also I pulled my SJ sticker off the pole when I did this.. I cant get the dang residue off even goo gone didn't work... anyone know what will take it off with out hurting the paint?
acetone, a hair dryer and a lot of patience worked for me
Acetone and a hair dryer at the same time can end EXPLOSIVELY. Heat to help remove the sticker....then acetone.
in the service manual they wrote hair dryer to remove the graphic and clean residu with isopropyl alcool im just finish with this and its work very wellacetone, a hair dryer and a lot of patience worked for me
I know this is a old thread, was just wondering those of you that ran thru bolts, I dont see how since the 3 top holes dont line up with the bottom 2? pictures of bolts used with length sizes would help alot. I bought 9 SS, 1/4 x 20 x 3/4in. I like the 2 thru bolts and the machine screws on the rest idea, but dont see how that can be done unless more holes are drilled out in the plastic?? 2, 3 1/2" inch thru bolts and 5 machine screws? Hope someone can help me out here lol..
Why through bolt?
Ideally the epoxy is what holds the pole to the bottom end, the rivets or bolts should only be to hold the pole/bracket in place while the epoxy dries.
Am I missing something?:dunno:
