- Asheville, NC
So I was finally able to try this with the ski on the trailer in the water. I tried the valve in every position and couldn't get any flow out of it. Maybe I was not hitting the throttle hard enough? I thought it would flow easier than that. I was whacking the throttle pretty good and nothing. Do I need to hold the throttle instead of just revving it for a blip?I always leave the ski strapped down tight to a trailer and back the ski in the water. I unhook the end going into the stinger and hold it over board and fire up the ski. At idle, you want it closed, low rpms closed, you want to adjust it to where you grab a handful and it opens. Or above “X” amount of throttle, or for technical terms, pump pressure. Tune away!
Yeah I followed the instructions per diem, no flow.The Arrow must point overboard, towards the Pisser.
It's a Check Valve, also known as a One-Way Valve. Only flows in one direction...
No flow at idle, and no flow with half throttle blips. Im thinking its my technique, not holding consistent throttle. I guess this is relatively easy to diagnose haha. But really what I'm asking is when you are giving throttle and checking the flow, are you holding steady throttle or just quick bursts?No flow... when? At idle? Or no flow at WOT?
I had a Y fitting originally and switched to a T. Also, Is your pisser straight through, 45, 90? View attachment 373117
