Hull Reinforcement...PICS!
kraqus
Yes DK, I already trim it and if I had to do it again YES you are absolutely right, use a hand blade THEN sand. I say this because you really want to minimize the amount of dust. Because NO MATTER how careful you are, sanding Fiberglass is a PITA because you get those fibers in your body somehow and then you are scratching for days......Damn!.
Next time I will get a Tivek suit.....
Benny
kraqus
My understanding is that it makes it weak....or weaker?
Specially if you have pools of it at some spots.
The strength comes from the glass itself, the actual cloth.
Resin can actually crack....and eventually does.
Benny
kraqus
It is the same as everyone else's. Just make sure you DO NOT get Vinyl-Ester Resin. They might try to sell you that one instead if you tell them you are going to reinforce a Jet-Ski.......Epoxy Resin all the way.....
Benny
