- South Florida
BIG vice - mounted to the left-hand side of a HEAVY workbench. Heat if needed. Cheater bar if needed..... but...
***The absolute key, I've found, is a closed-end, tight fitting, 6-point (or 12-point is OK too) wrench on the impeller tool. NO Crescent wrenches or even open-end
I never had trouble for years (even using a crescent wrench), but recently started crushing or deforming EVERY DAMN impeller tool - solas or skat - that I used. Closed end wrenches solved the problem!
Hitch mounted holder is sweet BTW!
I absolutely agree on the closed wrench. I have destroyed several prop tools before I figured that out and not one since. Getting a hitch tool because it is a perfect idea. Thanks blaster800!
