superjetguy
It's hard to speak without a tongue.
- lake hogan
Okay awesome. I'll just re use the gasket a few times until I find my goldilocks setup.. Thank you guys for all the help.
Lower your pop off to around 42 psi. Don't bother with high speeds until you do that. You not even reving high enough for the high speeds.
Is this a question like you think it's bouncing of a limiter?. That engine is no where near the limiter. It is breaking up half way up the rpm band. My guess is it's not getting strong enough spark weak stators and high compression will blow out the spark unless the plug is gapped really tight.Sounds like it is bouncing off the limiter?
New plugs and a tight gap should be the very first thing to do. It takes 2 minutes to do it.Try these in this order:
Unplug your stop switch - black/white wire down by your ebox (Will have to pull plug wires to stop engine, or turn idle down)
Try a known working CDI
Check that the ground is still good on your stator
Replace stator with known good stator
Really that close huh? I'll try it, thank you everyone for the help I'll head out soon and ride and give a ride report.
