- Chicago
38 Mikunis can be set up real nice.
Well I am interested to see what you can accomplish with this set up you're putting together. Race gas and that compression is extremely overkill for that pipe though. A dried out stock 650 pipe doesn't change the fact that its a 650 pipe. And I hope its not totally dry. That will be the major limiting factor here though. None of us who have successful 750 conversion skis use that pipe. Its just not big enough.
Sure a dry pipe or even the 750 limited pipe will be hard to fit, but you asked what it would take. You need a good pipe to have fun. You need an insane pipe with this configuration to get close to flipping.
Also a really good freestyle port job BTW. That with stock sxr Mikunis and Advent T3 are an amazing set up. Is your engine ported?
Has your ski in this configuration been on the water yet? Are you using a 650 or 750 pump? What impeller?
Anyway have fun with it and let us know how it goes. If you want more feedback start a thread in the vintage section on pwct and see what the responses are.
