Water on the head is just with the stock head. It's the little water take off for stock exhaust I didnt seal too well. The ADA heads back on it now. I had the cylinders decked becasue I originally thought water was leaking on the stock head gasket due to an overheat ages ago. They cleaned up 1.5 thou.
Yea, it has the miss with the hod off on and off in and out of the water.
The ign coil and leads were a new unit from Jetmaniac, I recon it's good in that department.
Over heat sensor is disconnected and leads are sitting nicely inside e box with insulation.
New excitor coil is Yamaha, new pulse is aftermarket but it starts first time and excluding the miss timing seems to be fine. It's never backfired.
Tank valve tests fine by mouth. Could possibly be fuel supply related but I really dont tend to think so.
Symptoms suggest it's ign related. I'm booking in with a mechanic whos going to hook it up to an oscilloscope. I need to rule out ign once and for all. Spark looks visually nice and theres nothing else I can check or change but I cant be certain that spark is ok.
