It's Flip To Be Square...
If you haven't noticed already I'm picky as hell! Gaps in the bond rail won't make the grade for my build. They needed some tending to.
Roseand
The Weaponizer
Wisconsin
Most SN builds are just the same old rocker and chop...
This one is hella interesting. Keep up the fantabulously clean work!
The sides of the tray are going to be more 19oz carbon. I'm going to make more flat sheets and then cut them into shape and put a slit in the bottom tubes. There will be 10lb foam in the tubes for strength. Then maybe rickter holds attached by some slash cuts in the carbon sheets to move the holds forward and back. And the tubes will punch through the fire wall/dash for strength.
Subbed, what's your plan for footholds/sides of the tray?
Wisconsin
Nice. I was hoping you werent just going to keep those gaps open, lol.. Later ACL after one fall
