I wouldn't drill a jet unless using it as a water restrictor. Never in a carb.
Never mind, I found the jet locally and get to do it the right way.
Wow, 150 pilot? Big toilet carbs with no venturi? Must be a seadoo...I can't see that a reed valved engine with a SBN modified carb you ever use anything that big? Is this a freeride/freestyle engine? Maybe Methanol and not gasoline?
Ok. RACE!!I know of several race lamey engines including mine that run 150 pilot and a little bigger in there NOVI carbs. And yes, they hit like hell!
Ok. RACE!!
