How do I buy one?
Message sent, check your inbox.
How do I buy one?
Im interested in a wb1 box also need it asapMessage sent, check your inbox.
I need one how do I go about getting this
@JetManiac i need one I can’t message you please email me or something arakid0307@gmail.comView attachment 342396
JetManiac is proud to announce the development of our newest freeride waterbox designed for WaveBlasters. This follows in the design of our popular standup hull waterbox:
http://www.x-h2o.com/index.php?threads/jetmaniac-waterbox.181445/
It is designed to replace a stock Waveblaster 1 '93-'96 waterbox both in hose connection location and fitment, but it is smaller, much lighter and sounds better. The OEM blaster waterbox is plastic and prone to cracks, leaks and top separation. We spent alot of time getting the fitment correct.
* Inlet and outlets are stock sized so standard exhaust hoses and Bpipe coupler to waterbox hoses fit.
* Inlet and outlet are flanged like stock to help prevent a hose from sliding off.
Weight comparison:
OEM B1 waterbox 8.4 lb
Riva B1 waterbox (discontinued) 8.4 lb
Factory Pipe B1 waterbox (discontinued) 6.4 lb
JetManiac B1 waterbox 3.9 lb
* The stock waterbox also holds much more water making the weight difference in use larger.
* Also this extra water is still in the stock oem waterbox after use and will not all braap out, so is more likely to cause condensation in the open exhaust port of your motor. JM waterbox is easy to brapp out water after riding.
Due to the smaller overall size the longer waterbox strap needs to be shorter. Ideal length is about 12" depending on how much padding is under the waterbox.
JetManiac B1 waterbox 279.90 intro sale 229.90
Not an easy box to build.
You can see the quality of the welds.
All waterboxes are welded by the same certified welder for consistent quality. (AWS D17.1 aerospace certification for aluminum, s.s. and titanium)
Welder is also a rider who understands its use and design. Particular attention was paid to the design of baffle and attachment to eliminate the 'loose baffle' problem so common with stock and some aftermarket waterboxes.
Compound angles to fit the Blaster hull bottom
I want one as well but I can’t send messages yet.
Has anyone talked to him lately ?
I am also interested but I can't find any message option; you'd probably sell 3x more of these if you had a store or some clear form of contact. Let me know how I can purchase please![]()
How do I purchase one of these water boxes for my wave blaster 1.View attachment 342396
Weight comparison:
Still need waterbox. How do I purchase?How do I purchase one of these water boxes for my wave blaster 1.
Sounds easy enough but I don't see a private message option.You send Jetmaniac a PM.
You need to post a few more times, then you can PM people. I can't remember the magic number of posts. 5 or 7 or something like that. So reply to this thread a couple more times and you'll be golden.Sounds easy enough but I don't see a private message option.
Go find where Jetmaniac has posted, Hold Cursor over name, you will see "Start Conversation", Click on it, type something in the "Subject" line, then go below and say "I need a waterbox"........ But you need to make a few more post to do so.Sounds easy enough but I don't see a private message option.
