- 28079 Indian trail nc
Thanks for the help, found him on Facebook and he immediately responded.
Send him a private message. @JetManiacHow do I purchase a wb1 water box from you?
Wild guess- for 2 blasters.For what you need two? o.o
Bought one but wouldn't mine having two more ..have three blasters .two of them cracked and the other stock is ok but why not if he's gottemFor what you need two? o.o
Hi I'dView attachment 342396
JetManiac is proud to announce the development of our newest freeride waterbox designed for WaveBlasters. This follows in the design of our popular standup hull waterbox:
http://www.x-h2o.com/index.php?threads/jetmaniac-waterbox.181445/
It is designed to replace a stock Waveblaster 1 '93-'96 waterbox both in hose connection location and fitment, but it is smaller, much lighter and sounds better. The OEM blaster waterbox is plastic and prone to cracks, leaks and top separation. We spent alot of time getting the fitment correct.
* Inlet and outlets are stock sized so standard exhaust hoses and Bpipe coupler to waterbox hoses fit.
* Inlet and outlet are flanged like stock to help prevent a hose from sliding off.
Weight comparison:
OEM B1 waterbox 8.4 lb
Riva B1 waterbox (discontinued) 8.4 lb
Factory Pipe B1 waterbox (discontinued) 6.4 lb
JetManiac B1 waterbox 3.9 lb
* The stock waterbox also holds much more water making the weight difference in use larger.
* Also this extra water is still in the stock oem waterbox after use and will not all braap out, so is more likely to cause condensation in the open exhaust port of your motor. JM waterbox is easy to brapp out water after riding.
Due to the smaller overall size the longer waterbox strap needs to be shorter. Ideal length is about 12" depending on how much padding is under the waterbox.
JetManiac B1 waterbox $349.90 sale 328.90
Not an easy box to build.
You can see the quality of the welds.
All waterboxes are welded by the same certified welder for consistent quality. (AWS D17.1 aerospace certification for aluminum, s.s. and titanium)
Welder is also a rider who understands its use and design. Particular attention was paid to the design of baffle and attachment to eliminate the 'loose baffle' problem so common with stock and some aftermarket waterboxes.
Compound angles to fit the Blaster hull bottom
Hi, I'd like to buy one of these B1 waterbox. Do you post to Australia?View attachment 342396
Weight comparison:
PM sent.I have a 1993 WB1 and my waterbox just blew. I would love to buy one of these if you are still making them. PM price and how to. Thank You
Those are beautiful. Any chance you have a couple left?
1 in stock right now.is the Blaster 1 water box available
Better get it quick! its a great option and not obnoxious.is the Blaster 1 water box available
