DAG
- Charlotte, NC
Product discontinued: 10/15/18
JETTLab would like to present you with an easy way to perform a leak-down test on your motor. Long are the days of cutting up bicycle tubes and sandwiching them between your manifold in hopes that the tubes will create an airtight seal across the bike tube seam and the frustration of the thin bike tube rubber warping under pressure making your newly created seal a 1 time use product.
JETTLab has sourced a rubber seal that is durable, chemical resistant, and air impermeable. The rubber seal is much thicker than your standard bike tube and is time proven to hold up over several leak-down checks with minimum signs of wear. You will be able to use the seals over and over again. JETTLab has also incorporated an optional pulse stem into its leak-down kit. The pulse stem allows you to connect a standard air pump up to the pulse fitting in your crankcase for an easy and hassle free way to pressurize your motor. With a typical tire pump (manual or electric), all you have to do is connect the pulse stem to your crankcase pulse fitting and flip a switch to pressurize.
The JETTLab Leak-Down Test Kit is a piece meal kit. You can pick and choose the pieces you need to build a bundle that suits the need for your particular setup.
Carb Blockoff Plate – $8.50ea
Exhaust Blockoff Plate – $14ea
Bpipe Blockoff Plate – $10.50ea
Carb Rubber Seal – $4ea
Exhaust Rubber Seal – $7ea
Bpipe Rubber Seal – $5ea
Pulse Pump Valve – $5ea
Thanks for looking,
Thanks for looking,
