grezzmky
Suckin paint fumes
- Saint Louis MO
I took the 35 domes out of my 4mm BB jetworks motor last year and went to 33s. I did not ride much last year and I put TL on at the same time so I cant say what it did... I did a compression check yesterday and only got 151 in each hole. Put a new stronger battery in today and got 180. took the (purchased used) 33s out and put the 35s back in and got 176.
The reason for the compression check in the 10 degree weather is cause I was talking to Art about an impeller yesterday and when we were talking about my setup he kinda freaked and said the 33s would give me over 220 lbs compression. and that they have special 34s cut for upgrading from 35s.
2 questions, What are other peoples compression with Arts motors?
and what should the difference be on 35 to 33 domes on 84mm slugs?
